Ok, my old laptop crashed. I purchased a new laptop with windows 7 professional 32-bit When I try to install the version 7.5 I get an error message. "bad CRC this indicates that your setup file might be corrupted. version 8 installs fine. Any Ideas?
had this problem once before, I re-downloaded file and tried again and it worked.
are you installing as administrator?
CRC will be due to a corrupt download. Download again and hopefully you should be fine.
Download again, from here: Builds 136/120.
Ok, I got it. I tried downloading the file like 6 times. Tonight it worked. Thanks for all the help
