1 Attachment(s)
Can do.
That valley in the Cranking VE is there to compensate for flooding on startup with that Marine intake. If im not mistaken. Its been a while.
Got the rest of it done.
Trims should be re-enabled...
Just got some news from my engine shop on the motor.
Looks like one of the transmission I had hooked up to it at one point pressed very aggressively on the crank destroying the main seal and chewing up a bit of metal inside the engine. So all that has t be repaired as well.
I highly doubt it was the Circle D tourq Converter that cause that issue. I would be more included to guess that it was the junk transmissions from Mad Dog Transmissions. Just another Bunch of $'s because of going with those guys.Attachment 22010
It probably wore into the thrust surface of the main bearing (#3).
Yea Very sadening but hey... Its all part of it i guess..
Really looking forward to doing the calc VE instead of the way I was working with that setup before... It was difficult. So much better to run Calc VE
Calc.VET (improved variation on Calc.VE) is fairly easy to run...
see here: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
Id like to get this maf running in my setup.
I have an adapter for the plugs.
But what do I need to change to get this working.
https://www.amazon.com/ACDelco-213-4.../dp/B0010GDGFY
https://www.amazon.com/ACDelco-213-4...ype=automotive
2010-2015 Camaro Mass Air Flow Sensor AcDelco
Its a K-9 the fast sensor.
PS: the MAF was previously disabled in my original tune.
Put the MAF diagnostics settings back to stock (look at C2901-6).
1 Attachment(s)
I think i just about got everything back where it goes. Machine shop is just about done with the rebuild.
im installing a 6" lift in the front now.
Attachment 22277
I will post logs as soon as I turn the key.
What I would like to do it's run an ls3 card style maff. I had heard you can change a couple parameters then do a calc be sand calc maf. Getting everything lined out that way and having the 4" intake time.
Any suggestions as to what I should change in the time to make it runner first time out?
MAF table would be the only thing needing correcting (i.e. do AutoMAF or half of Calc.VET).
