2 Attachment(s)
LS1 Straw Blower/Mulcher Conversion
Hi,
Been awhile since I posted; feel free to move this post if it's in the wrong section.
This forum is such a great resource for help so here goes:
I have found a 2000 Camaro Ls1 from a NYS Thruway cop car that was rear ended. I have the complete package to re-power this old Reinco straw blower that originally utilized a Wiconsin W4-1770 35 hp engine that the owner said never had enough power to do the job from brand new.
My challenges are many but I have for the most part figured this out, my goal is a standalone engine power plant that can be easily removed for servicing yet still run while "off" the machine.
I do not have drive by wire so I purchased a mechanical belt driven governor that will mount where the A/C compressor once was.
The original RPM was 2400 and I must be very careful as not to blow thru that window and kill or injure an operator as the impeller weighs about 90 pounds and has about a 2 foot blower fan.
To start is there a "simpler" if you will operating system that can be flashed into this LS1B (I believe) PCM that would have no rear O2s or secondary air, EGR, MAF or must I start deleting things from the original operating system? I thought maybe if GM used the LS1B on other applications or non-emissions applications I could find the flash.
If I use a tune from a manual transmission car should I run a speed sensor on the blower shaft? It's easy enough to do but not sure if I'd need one.
I'm guessing that I can find a table for rev control that would kill injectors or the fuel if someone overrides the mechanical governor.
I know this LS1 engine probably does not have a huge amount of torque at 2400 RPM, the W4-1770 had about 70 foot-lbs. at 2400.
Yeah it's a mess I know and needs lots of TLC.
Thanks for the help, John
Attachment 19185
Attachment 19186
