06 ECM connection problems
I have a 2006 Cummins that I cannot connect to.
I use just the V2 to scan for codes and it fires up just fine I go and try and scan for codes and it says: Error $0280 cannot connect to ECM
I try and run 7.5 scan and it will not let me do any scanning. I select the cummins 849 ecm and it says Cummins on the lower part of the screen then 10-15 seconds it switches to Generic but it has the correct VIN #.
I bought the $450 Cummins tune unlock.
The V2 is black and I bought in 2007.
I am running the latest update.
I can Scan the truck with a Snap-On Solus just fine.
Bob
Well I think I finally figured out my problem.
My brother ordered a new V2 to OBDII cable last week.
Today while I was trying to scan a 2011 LML for the ECM serial number I was having the same error code. Troubleshooting led me to the V2 RJ45 connector. When I moved the cable it would cycle the V2 power.
Two of the pins, (#1, #2)were bent down and not touching fully to the cable. I tune my LB7 more than any other vehicle. The LB7 doesn't use the #2 pin but Can systems do.
http://images.tapatalk-cdn.com/15/04...596d399d7b.jpg
I got a hold of Guy Tripp at SoCal diesel. He said not problem just send it in and he will take care of it.
Bob
