Idle issues after fixing MAP sensor leak!!!
Hey guys, I just fixed a leak that I had on the tube that goes to the map sensor and wasnt letting me run in SD. The motor idled fine before with just the MAF but now that I fixed that leak the motor hardly runs with just the MAP and with MAP and MAF it runs a very weak idle, if I rev it, it drops down to 300rpms and is hunting for idle for a few seconds then it finaly sets in at 950. Without the maf it idles very rough and if I rev it when the rpms come down it just dies.
Is this something I can easily fix as I belive it only needs a little more air at idle to compensate for the fixed leak. I'm a newb still so if you can tell me which tables I would :master:
Thanks,
Paul.
