vs commodore ute
hey i received no chatter when i ran efilive, am running on windows vista ultimate, on an acer aspire laptop.....if any can help me out as to what i need to reconfigure to get the chatter to respond and then proceed with running the diagnostic?
cheers all
I don't think the VS ECM's send out any chatter.
if my vehicle does not send out chatter then what things can i do with this program.......
maybe this helps?
57:19.801: Initialising...
57:20.052: Opening COM2 8228,8,N,1
57:20.592: Ready.
58:05.057: Start macro: Clear diagnostic trouble codes: CLRDTC
58:05.056: Start writing frame
58:05.058: Send: $F5,$57,$0A,$00,$AA
58:05.060: Finished writing frame
58:05.067: Stop macro: Clear diagnostic trouble codes: CLRDTC
58:13.704: Check vehicle interface...
58:13.710: Waiting for Aldl bus silence of at least 50ms...
58:13.761: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
58:13.764: Start writing frame
58:13.765: Send: $FF,$55,$AC
58:13.767: Finished writing frame
58:13.769: Wait 10 ms after writing, before reading...
58:13.780: Start reading frame
58:13.783: Aldl frame header byte: $FF
58:13.786: Aldl frame length byte: $ 0
58:13.787: Recv: $FF,$55,$AC
58:13.789: Finished reading frame
58:13.790: Max232 interface detected OK
58:13.804: Scanning for heartbeat and chatter frames...
58:13.812: Waiting for Aldl bus silence of at least 50ms...
58:13.864: Start reading frame
58:13.966: Com timeout: Expecting frame header byte
58:13.968: No chatter found
58:28.956: Start macro: Clear diagnostic trouble codes: CLRDTC
58:28.957: Start writing frame
58:28.960: Send: $F5,$57,$0A,$00,$AA
58:28.963: Finished writing frame
58:28.970: Stop macro: Clear diagnostic trouble codes: CLRDTC
59:04.033: Start macro: Clear diagnostic trouble codes: CLRDTC
59:04.033: Start writing frame
59:04.035: Send: $F5,$57,$0A,$00,$AA
59:04.036: Finished writing frame
59:04.041: Stop macro: Clear diagnostic trouble codes: CLRDTC
05:46.814: Scan for chatter...
05:46.816: Waiting for Aldl bus silence of at least 50ms...
05:46.867: Start reading frame
05:46.969: Com timeout: Expecting frame header byte
05:46.971: No chatter found
05:46.975: Start reading frame
05:47.077: Com timeout: Expecting frame header byte
05:47.079: No chatter found
05:47.082: Start reading frame
05:47.193: Com timeout: Expecting frame header byte
05:47.195: No chatter found
05:47.196: Start reading frame
05:47.298: Com timeout: Expecting frame header byte
05:47.300: No chatter found
05:47.302: Start reading frame
05:47.403: Com timeout: Expecting frame header byte
05:47.405: No chatter found
05:47.407: Start reading frame
05:47.508: Com timeout: Expecting frame header byte
05:47.510: No chatter found
05:47.511: Start reading frame
05:47.613: Com timeout: Expecting frame header byte
05:47.615: No chatter found
05:47.621: Start reading frame
05:47.723: Com timeout: Expecting frame header byte
05:47.725: No chatter found
05:47.727: Start reading frame
05:47.829: Com timeout: Expecting frame header byte
05:47.831: No chatter found
05:47.833: Start reading frame
05:47.934: Com timeout: Expecting frame header byte
05:47.936: No chatter found
05:47.938: Start reading frame
05:48.039: Com timeout: Expecting frame header byte
05:48.041: No chatter found
05:48.043: Start reading frame
05:48.144: Com timeout: Expecting frame header byte
05:48.146: No chatter found
05:48.148: Start reading frame
05:48.249: Com timeout: Expecting frame header byte
05:48.251: No chatter found
05:48.252: Start reading frame
05:48.354: Com timeout: Expecting frame header byte
05:48.356: No chatter found
05:48.358: Start reading frame
05:48.460: Com timeout: Expecting frame header byte
05:48.463: No chatter found
05:48.465: Start reading frame
05:48.567: Com timeout: Expecting frame header byte
05:48.569: No chatter found
05:48.571: Start reading frame
05:48.672: Com timeout: Expecting frame header byte
05:48.674: No chatter found
05:48.677: Start reading frame
05:48.779: Com timeout: Expecting frame header byte
05:48.781: No chatter found
05:48.782: Start reading frame
05:48.884: Com timeout: Expecting frame header byte
05:48.886: No chatter found
05:48.888: Start reading frame
05:48.989: Com timeout: Expecting frame header byte
05:48.991: No chatter found
05:48.993: Start reading frame
05:49.096: Com timeout: Expecting frame header byte
05:49.098: No chatter found
05:49.100: Start reading frame
05:49.201: Com timeout: Expecting frame header byte
05:49.203: No chatter found
05:49.205: Start reading frame
05:49.307: Com timeout: Expecting frame header byte
05:49.309: No chatter found
05:49.312: Start reading frame
05:49.414: Com timeout: Expecting frame header byte
05:49.416: No chatter found
05:49.418: Start reading frame
05:49.520: Com timeout: Expecting frame header byte
05:49.524: No chatter found
05:49.526: Start reading frame
05:49.627: Com timeout: Expecting frame header byte
05:49.629: No chatter found
05:49.630: Start reading frame
05:49.732: Com timeout: Expecting frame header byte
05:49.734: No chatter found
05:49.738: Start reading frame
05:49.839: Com timeout: Expecting frame header byte
05:49.841: No chatter found
05:49.844: Start reading frame
05:49.945: Com timeout: Expecting frame header byte
05:49.947: No chatter found
05:49.949: Start reading frame
05:50.051: Com timeout: Expecting frame header byte
05:50.053: No chatter found
05:50.055: Start reading frame
05:50.157: Com timeout: Expecting frame header byte
05:50.159: No chatter found
05:50.161: Start reading frame
05:50.263: Com timeout: Expecting frame header byte
05:50.265: No chatter found
05:50.267: Start reading frame
05:50.368: Com timeout: Expecting frame header byte
05:50.370: No chatter found
05:50.372: Start reading frame
05:50.473: Com timeout: Expecting frame header byte
05:50.475: No chatter found
05:50.489: Start reading frame
05:50.590: Com timeout: Expecting frame header byte
05:50.592: No chatter found
05:50.598: Start reading frame
05:50.700: Com timeout: Expecting frame header byte
05:50.702: No chatter found
05:50.706: Stop scanning for chatter
Its a good thing that your vehicle does not chatter. Chatter is just comms data that is constantly sent between modules, it interferes with data logging. When chatter exists, EFILive must explicitly tell the various modules to stop chattering before data logging can proceed.
If there is no chatter then data logging is easier and causes less "grief" to the system. When each module expects to see the chatter data, then when it is stopped by EFILive the modules may set trouble codes indicating "loss of communications". So be happy your system has no chatter.
All you need to do is open the appropriate VS data stream file and click on the ALDL button to start data logging. No need to worry about chatter frames opf trying to suppress them or work around them.
P.S. EFILive V4 was developed using the VS-V8 Commodore as the test vehicle. So it should work perfectly for the VS-V8.
btw my car is a vs v6 no different there i imagine, where can i open the vs data stream, then after i do that do i then just start the car as at the moment the key is on at the ignition? i have very little idea about all this, i just dont want to do anything thay may harm the ECM or other electronics?
You won't harm anything by running the scan software.
Load the gmh-vr68vs8.xml file, using the File->Select vehicle, menu option.
Start engine.
Then click on the green ALDL button to start logging data.
