+1 thanks for posting back with the real problem/solution. :cheers:
No problem guys :thumb_yello:
Thanks again for all the help.
Thought I would share my findings with you guys. I’m running the 12614088 OS with a 6.2 from a GMC Denali that was transplanted into a Street Rod. I did everything this thread listed to do. Without the VATS patch the engine would turn over but no spark and no injector pulse. After the VATS patch we got spark but still no injector pulse. We had to apply a 100 Ohm resistor to pin 52 on the X1 connector to get her to fire up. And yes we tried the G1220 and it made no difference. Hope this helps someone else. This thread was a life saver for us.
I just did 2 E38 Truck OS (2007 5.3ltr 12605898) (2008 6.0ltr 12617631) this week and didn't need starter relay or resisitor...Both fired up on first try...:D
Just got efi live and got it hooked up to my harness, just chose disable on vats but i guess didnt apply patch cause i dont know where you get it or really what its about, can anyone help? E 37
i turned everything off i could find in tuning options and whatnot then did total reflash but dont see anything about vats patch in v8 or 7.5, v8 doesnt really do anything but flash and read for me am i messing something up?
That is correct...
V7 software does the following:
- scanner,
- logger,
- calibration editor,
- ECM flash reader/writer.
V8 software does the following:
- ECM flash reader/writer,
- V2 setup/options configurer.
