2 Attachment(s)
High milage 2001 Denali cold idle
Hopefully, someone out there can point me in the right direction before I get too carried away.
This is a 6.0L Yukon Denali has 309,000km with some minor mods. I bought it with the cats deleted. It also has one of those dumb throttle spacer "tornado" air spinny thingys. Usuallly it runs very well, except... When it is freezing out and the engine is cold. The engine will fire and then really misbehaves until the engine temp comes up a little. Sometimes it stalls after start up. I am tempted to lower the desired airflow a bit. But I suspect there may be a mechanical issue instead. Here is my tune and scan.
Attachment 14113Attachment 14114
I have noticed that the IAT is not really correct, because it was below -10deg C
