Need Help after new computer purchase...
I recently had to get a new computer and am having trouble getting the software to work correctly. I am unable to flash or read calibrations from ECMs. I have tried it on 2 seperate trucks (LMM and LBZ). Each time I get the same error that pops up.
23:17:20.381: Scanning for EFILive FlashScan V2 HAPI
23:17:20.397: Autodetect interface ...
23:17:20.553: Interface firmware version: 2.7.14
23:17:20.553: Connection to [FSV2] interface is OK
23:17:20.553: USB driver version: 4.0.0
23:17:20.568: USB library version: 3.1.18
23:17:20.568: Interface firmware model: FSV2
23:17:20.584: Interface firmware version: 2.7.14
23:17:20.584: Interface firmware date: Jul 03, 2011
23:17:20.599: FlashScan serial number: 003829992753
23:17:20.615: FlashScan license number: 003829992753
23:17:20.631: Disconnecting ...
23:17:20.974: CAN-VPW Bridge Deactivated
23:17:20.974: Disconnected
23:17:21.613: Scanning for EFILive FlashScan V2 HAPI
23:17:21.629: Autodetect interface ...
23:17:21.847: Interface firmware version: 2.7.14
23:17:21.847: Connection to [FSV2] interface is OK
23:17:21.863: CAN-VPW Bridge Activated
23:17:21.925: Current protocol set to: "ISO 15765 CAN"
23:17:21.925: Autodetect ECM...
23:17:21.941: Connection to ECM is OK
23:17:21.957: Current protocol: "ISO 15765 CAN"
23:17:22.159: USB driver version: 4.0.0
23:17:22.159: USB library version: 3.1.18
23:17:22.175: Interface firmware model: FSV2
23:17:22.191: Interface firmware version: 2.7.14
23:17:22.191: Interface firmware date: Jul 03, 2011
23:17:22.206: FlashScan serial number: 003829992753
23:17:22.206: FlashScan license number: 003829992753
23:17:22.440: Getting status...
23:17:22.830: Status: OK.
23:17:22.830: Request VIN...
23:17:24.515: VIN: 1GCHK29657E565244
23:17:25.233: Preparing ECM for reading flash...
23:17:25.248: ECM seed is: $8E69
23:17:25.248: Unlock attempt 1 of 1
23:17:25.373: Initializing ECM...
23:17:26.637: Error: Failed. Controller has returned to normal operation, please retry the operation.
23:17:27.292: Total time: 00:00
23:17:27.292: Rebooting ECM... (please wait up to 8 seconds)
23:17:28.415: ECM has booted successfully...
23:17:29.429: Clear emisison related DTCs...
23:17:29.445: Clear DTCs for all modules...
23:17:31.519: Autodetect interface ...
23:17:31.722: Interface firmware version: 2.7.14
23:17:31.738: Connection to [FSV2] interface is OK
23:17:31.738: Autodetect ECM...
23:17:31.738: Connection to ECM is OK
23:17:33.017: Disconnecting ...
23:17:33.563: CAN-VPW Bridge Deactivated
23:17:33.563: Disconnected
23:17:42.371: Done!
I have updated both the V7 and V8 software, updated the bootblock and firmware, and reverted to the old USB drivers with no success. I have been able to successfully flash a TCM, but no luck when trying ECMs.
Any suggestions would be appreciated. Would really like to get this resolved asap so I can make a few changes to a customers truck before a sled pull tomorrow night.
Also will all my previous licenses carry over without any trouble, or will I have to manually re-enter the activation codes I received when purchasing them?
