What does serial V2 switching of tunes equal to in what position.
This is the default naming for serial switch tuning of 1 through 5. What I am wondering is what does #1 equal to. I assume #1 is the base tune. Then #2 is actually DSP1 tune, #3 is DSP2, #4 is DSP3, and #5 is DSP4. Not able to test this but someone asked me if I knew which number went to which DSP1-4 or base tune. I thought of select the DSP5 PID but that is for the switch only setup to check with. Look through the DSP doc with but did not see which one was what. Also searched here for ' DSP5 serial ' but may have missed it in one of the 130 some post. If someone can fill out the below to mach what it does that would be great.
1 Stock tune =??????
2 Smokeless=??????
3 Economy=??????
4 Power=??????
5 Towing=??????
Thank you for your time and help.
Brian
