Mick,
Ok I was sanity checking just in case the dots had crept in
(I have plenty of experience in the field of characters creeping in... :hihi:).
Cheers
Joe
:cheers:
Joe,
Over the weekend I did some work on the base files improving the Factor Scalers, including Imperial Values and generally fixing a few errors. I found another supported OS. Can you have a look over these files and add the LC. If your happy you can update the files thread.
There is one more OS I see that I could support in the 2001, 2002 family, OS: 12209203 but I don't have a base tune file to work off so if any one has one it would be cool if you could post it.
I had a good look at the 2003 family of OS this weekend, starting with OS: 12593058. These jumped up in file size from 512kb to 708kb and the code has moved around quite a bit so I will need to change my plan of attack here. I found a few tables that are possibilities but really need to start working in binary format to make some break through. It would not surprise me if the tables changed in there appearance and there were a couple more that are included in the code.
This is the direction that I would like to head in, will keep chipping away at it.
Cheers
Mick
Mick,
Ok, I'll go thru those and I'll integrate and post.
Thanks,
Joe
Ok, I edited/merged lean cruise into those, and I made all files have uniform format (the numeric content did not change, of course)...
I'll post these updates to the cax updates thread.
Mick,
I made the files uniform since this makes it easy to see the numerical differences;
if these are ok, then please use these for any further work.
showthread.php?p=79912#post79912
Thanks,
Joe
