Attachment 23937
Lets see if this goes through.
Attachment 23937
Strange. That shows up as different files.
Is it possible something was corrupted on the PCM side?
Correct, The files are different.
When I attempt to compare both files, I get the correct error showing they are different files. On both V8 and V7 software.
The only thing that changed was I manually stopped mid flash and then did a recovery earlier in the day. Perhaps something was corrupted in the PCM and it was corrected when I did the recovery.
Either way I am Grateful for the help I have received.
Thanks for sending those test files and trace files. The files do show that everything flashed correctly and read back out correctly.
Please let me know if the problem occurs again.
Is the PCM a RoadRunner PCM by any chance?
No it is not. Just a Spare PCM for my personal Vehicle.
I was told the 1MB PCM's do not function correctly with the road runner and they discontinued support. IT only appears to work for the 512Kb 99-02 style pcm's. I have never had the chance to play with a roadrunner PCM.
Update 1 has been released here: https://forum.efilive.com/showthread...Public-Release
See the "What's New" for changes and updates.
