[QUOTE=griffincox;244149]Any more info on how to enable Class 2 on a E67 that doesn
What os?
Bump. Looking to have a LSA/LS9 OS run a 2008 GMT-360 with Class 2 functional. Any help?
Well there is no actual os for lsa worh class 2
I used the 09 tbss
I made everything work other than iat2
However as others na to blower swaps i put the iat2 sensor to iat wiring
Sent from my SM-N950U using Tapatalk
If you have to pick a single year, do 09 TBSS first as it both the extended MAF and IFR tables. 07/08 are pretty similar and will run the same. 08 has the single, extended MAF table (but no extended IFR) vs 2 on the 07s. Can run an 07 OS in an 08 and vice-versa, so no real reason to do 07 over 08. 06s, well yay E40 there.
