911 HELP - Wideband Serial Connection Inoperable
Hey,
This message is especially for Joecar, as I've followed his steps to try and make this work. I have a V2, a Null Modem Cable I made, and a LM-2. Used the Innovate and V2 Cables, and connected it all as it should. Multiple Issues:
1.) When the LM-2 is reading correctly, I can play with the RS-232 Plug on the V2 and and have it intermittently display the WO2. The rest of the time, it shows WO2 Not Found.
2.) I am using EFILive Scan 7.5, and this will read the WO2 PID when I intermittently seem to get the plug on the V2 to work. The LM-2 also freezes at 18.0 sometimes as soon as the V2 begins logging.
3.) I am running the LM-2 through a cigarette lighter adapter, on a Booster Pack as my racecar does not have anyway to give the LM-2 12V right now. Could low voltage to the LM-2 be causing all these issues.
Any help available?
