The v2 and the Edge insight use the same data port connection. How hard is it to connect and calibrate the insight sensors to the v2?
I don't want to complely disable the insight but just tap into the sensor wire and run it to the v2.
I will have to disconnect the insight from the data port to connect the V2 to log then plug the insight back in after I am done.
Rick
