On my LBZ, I d/led those updated files. Still can't get it all to work.
I got the throttle position to work not but the others still don't. I attached some images. Any ideas what I have wrong? I have tried to validate PIDs a number of times.
Have you downloaded the latest and greatest files from here. Also make sure your V2 has the latest firmware.
Yup, everything is updated with the newest files.
Sorry I can't be of much help since I don't have LBZ experience. I've never run into this problem on the 2nd gen LLY.
Ok well I deleated the .vlp file for my truck. Re-started everything. The controller is selected as LBZ. Still no go for boost, barametric pressure, Main and Pilot injection. I generated an error report in hopes that someone might read through it and find out what is wrong. The report is 1.73 MB so I can't upload it. If any of the EFI team would like it please let me know and I can mail it. I got the throttle position working, temps are working, vane position and fuel pressure works.
Mail the error report to: support@efilive.com
Perfect, just sent it. ThanksQuote:
Originally Posted by joecar
This may help...
http://forum.efilive.com/showthread....2551#post42551
I have installed that update. Didn't solve the issue though. :frown:Quote:
Originally Posted by Blacky
I've been having trouble with boost PIDs also. I can get barometric pressure to validate and I can read MAP with that PID, but it gives me boost as InHg instead of PSI. It's really more of an inconvenience than anything because I have to convert, but I would prefer to read boost as PSI.
