E78 - 2017 Sonic 1.4t Code 95 Code 84 on dash
Hello everybody,
Need some help here, just flashed a 2017 Sonic 1.4T and 2 things are happening, once I connect the efilive unit on the OBD and the engine is on the code 95 pops up on the dash and gauges shut down, traction control light on and some others on, well I have to do logs so i am kind of blind, checked logs all ok and then removed everything went for a drive and 100 mts driving and code 84 on the dash, try to check DTC's with efilive, everything is clean, used launch scanner and clean, any clues to what might be happening, there is no apparent power loss when code 84 pops up.
tahnks in advance,
Alejandro
