From memory changing HO 0150 to 203 started things on the right path for me
Its all spot on now
Let me know how you go and I can send tune
So i changed H0105 to 182
H0122 to 8
Modified the PPK value in my dash cluster to 3000 as that is the lowest it will let me input. If i could change it to 2600 i'd be much easier.
Now the TCM reports 100kph. ECU - 120~122 ish.
Dash Cluster matches TCM speed
That's with a 3.73 diff gear, I'll be changing to a 3.08 after the new year.
