I'm not sure about the diesel programming but have had similar issues with gas PCM swaps and OS changes. It is in which way the OS was set in parameters
G1001 to G1009 with an emphasis on G1006.
HTH!
HTH!
Sorry, this is actually for a 1999 GMC Sierra 1500 rcsb with a 6.0 that originally had a 5.3
This just came up in search, and didn't realize it was in diesel section until part way into thread conversation
Also when I type in G1001 or G1006 in tune tool it isn't found, that must be for different ECU or OS than mine
You're on your own there then. I have no idea about gas engines.
