How to scan speeds faster than 158 mi/h (255km/h)?
Hi,
if I use the SAE VSS pid it works fine until the limites are reached.
If I try to rescale it in EFIlive it has the new max level but still stops at the limit, What causes this? Is it an SAE hardware limit? Can it be changed?
I can calculate the "real Speed" by using a correction factor to the RPM pid in last gear but this should be only a band aid.
At the Autobahn here in Germany I tried to do a topspeed run with our supercharged Corvette C5 and was hoping to see 200+ mi/h (320+ km/h) and so it would be really useful :notacrook: !
Anyone else already noticed this problem?
many thanks & best regards from Germany
Marco
