How can I select say 8 cells in a row to smooth, out of the 17 total cells of on for example the fan power ect??
Quote: Originally Posted by 2010 Bumblebee How can I select say 8 cells in a row to smooth, out of the 17 total cells of on for example the fan power ect?? Using the mouse/cursor click-and-drag across the cells you want highlighted... do this on the tabular display [lower pane] or on the 3D graph [upper pane] (click the 3D button to force a 2D graph to display as a 3D graph).
Quote: Originally Posted by joecar Using the mouse/cursor click-and-drag across the cells you want highlighted... do this on the tabular display [lower pane] or on the 3D graph [upper pane] (click the 3D button to force a 2D graph to display as a 3D graph). Thank you that worked. Now I know how to do one thing with th program ! I'm getting there !
