PCM driven shift light on an auto
I am using 01290005 operating system and trying to use the air pump output pin red plug pin 36 to drive a shift light at a programmed RPM.
Activated air pump in the platform and adjusted the setting in the Air pump parameters did not work.
While I am running 01290005 operating system which was converted from an Australian operating system is it possible the Australian operating system/tune does not have the relevant information to drive the air pump output!
Can anyone offer any suggestions?
