SAE.TP (Absolute Throttle Position) not reaching 100%
I notice no matter how far I push the peddle I can't seem to get over 93.7% for the SAE.TP PID. The same seems to apply for the default supercharged Monaro data logs that come with EFILive (didn't go past 90%).
What should I look for to get my throttle position to read 100% instead of 93.7%?
Re: SAE.TP (Absolute Throttle Position) not reaching 100%
Quote:
Guess what, that car had an issue with the throttle cable, it was only getting to 90% at the blade it was discovered :oops:
Once you tell us the voltage the TPS is reading that will give a pretty good indication of just how far it is opening.....also, what the TPS voltage is when the throttle is shut.
