trans shift points?
I have a (01)2500 silverado with 6.0 I'm trying to move the shift points down at WOT because of a rev limiter I set at 4500rpm I changed parameters D0910-D0912 for 1>2 and D0915-D0917 for 2>3 also I changed D0940-D0952 And still I cant get the shift points for WOT below the rev limiter .Any help will be great.
This is the Diesel section. For the trans to shift, it has to hit 2 perameters, Miles per hour Then / Or Engine RPM. Both conditions have to be met before Soloniod actuation will be made.
Also make sure the following are met:
D0925-D0927 < D0910-D0912
D0930-D0932 < D0915-D0917
(about 10 mph difference is good).
Edit: see correction (sorry I type badly)
Hey thank you for the help ,I tried it this morning and it all works great.:) Sorry about putting it in the diesel section . Were should it go?
I'll move it to Petrol/Gas->General...
Why did you set the rev limiter at 4500??
Company trucks,enough said right? Hey thanks joecar for moving it. I'm such a rookie!
No worries... :cheers:
See post #3 again, I corrected my stupid typo..., but you figured it out already.
me-> :bash: <-typos
