April 2015, EFILive Public Release
April 13 2015, Public Release
Release Notes:This public release is identical to the April 2015 RC2 software. If you have already downloaded and installed the RC2 software then you do not need to download and install this public release.
If you have an older version of the software installed and you perform a "Check For Updates", you will see a message indicating that t newer version is available but that no patch exists that can be automatically applied. To obtain the latest public release you must download and install both V7 and V8 from here:
http://www.efilive.com/latest/cat/download-efilive
Please read the warnings and imporatant information in the release notes before installing or running the EFILive software.
Release Notes.
Known Issues:Check for known issues
here.
Please post new issues, questions or clarifications (large or small) in this thread.
As new issues are verified they will be posted in the "known issues" thread above.
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 281
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 275
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.82 (Apr 10, 2015)
To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
The EFILive Development Team
