Reading PCM with Z06 Door Ajar :S Check Engine
Man did flashscan get cranky, not to mention the Z06
It was going along just fine, until it hit 204kb and the clock was counting down. Then the dash started like it was going through every single check, then threw a check engine light and sat at 204 Kb, and time shot to 11:20 minutes and never moved from there, just cycling over and over.
Just stopping the read, waiting the 15 seconds, starting the car with Scan open and clearing the codes, which were all, PCM could not communicate errors listing everything we saw on the dash.
Then we both opened and closed both driver and passenger door to make sure both were closed and started over.
Read was successfull this time :)
Also did some Scans, not sure if this is expected but while tune and scan were both open, SCAN stopped showing the gages, I checked the data and it was logging???
Shut off TUNE and restarted SCAN and all was happy.
So 2 weird anomolies with remedy :D
WOW is the Z06 VE table stock SMOOTH. NOT FAIR my GTO and SS looked like the rocky mountain.
