EFILve indicated to ask efilive if i have a real need for this... I want to bypass OS compatibility checks... This requires a pro license... How may i purchase/obtain this?
What are you trying to do...?
Send an email to sales@efilive.com explaining your requirement for a Pro License. Before obtaining a Pro License you will be required to sign and return a Pro License Waiver document.
You could try with TIS, pretty sure it'll do it if all the stars align for what it is looking for.
Yeah, I think what GM dealers get vs ACDelco's version is different.
Acdelco shows the history correctly for other vin's that I have, but this one zr2 shows an os that isn't on TIS... It's real weird because all the other vins I check, have an os that is found on the history of calibrations. 55504430 doesn't show under the vin read from the ecm. I'm using that os from my17 and I'm needing that os on my18 and I'm stuck with the os compatibility. Haven't tried TIS yet and I didn't want try the mongoose and reup a subscription to test an unknown
Sent from my LG-H918 using Tapatalk
