Just enquiring whether it is possible to add the Motec PLM to the list of serial devices for V2.
I have attached the PLM user manual which should have all info required for RS232 data ....
Cheers
Kyle
Cheers
Kyle
I know its any old thread ....any chance of this happening Paul?
Paul is on a break for a week, hopefully it won't be 2 years before you get an update :doh2:
Somehow I didn't see this thread two years ago... :doh2:
[ please bump the thread if you don't see a response after a few weeks ]
I don't see any reason why it can't be done. What would help is if you could hook up the wide band controller described in the pdf document to FlashScan's serial interface.
Then set up FlashScan to use either the AEM or Zt2 wide band controllers. Use only those two settings because they match the same baud rate as the one specified in the pdf. (i.e. 9600 8,n,1)
Make sure the Left most orange LED on FlashScan's keypad is flashing - that indicates FlashScan is receiving RS232 data which means the physical connection is ok.
Then wait for about 5-10 seconds to allow FlashScan time to record some of the RS232 data from the wide band controller.
Then save a trace file on FlashScan, copy it to the PC using EFILive Explorer and email it to me.
Also in the email give a brief description of what data the wide band controller was outputting at the time, i.e. Lambda values, or an error, or a status such as "warming up".
Include a link to this thread so I know what the email is about.
Thanks Paul ,
Will get onto it as soon as I can .
Cheers
Kyle
Hey guys , have we gotten anywhere with this ? ( sorry to dig out an old thread )
Hi Paul
I now have 3 Motec PLM units .... if you have the time can you look at serial integration.
The PLM manual is here - http://www.motec.com.au/plm/plmdownload/ . It should contain info you require .
Im happy to help with testing as required .
Cheers
Kyle
