Is it possible to manually delete frames from logged data?
Please tell?
Please tell?
Ahhhhhhhhhhh
Using the the left and right arrow buttons, position the vertical line at one end of the data you wish to hightlight, then while holding down the shift button press left or right to highlight data you wish to delete...
Or hold the left mouse button down as you drag the vertical line cursor across the chart (highlights a portion of the log), then press the delete frames button on the bottom of the scantool window (has a red X on the button); then save the log file.
