Commanded AFR going out of spec
Hello Guys,
I am having an issue where all of the sudden the commanded AFR will go from the 14.68 Closed loop into "open loop" and 15.69 or 13.59 AFR.
I have set all my open loop afr tables to 14.68 but I am still seeing those changes under unknown conditions...
I have seen this on 2 cars... The first one I didn't pay much attention and the second one... Well... it's time to chack...I have tried pretty much everything... It appears to be a random thing...
It will keep the last used STFT and LTFT and command a leaner 15.69 and/or a richer 13.59 on normal cruising... if you punch it, it will drop to PE normally... but still...
COT is OFF
Any ideas?
