I have a 2011 Camaro L99. I was just wondering if the 2010 had the same tunes for the eng and trans.
Bill
Bill
post the 2011 tune and i can compare it to the 2010 one
Here you go.
Thanks.
Bill
had a bit of a look and found that the speed limiter (2010 tune 250kms 156mph , 2011 tune 512kms 320mph)has been removed in the 2011 tune,plus the pulse's in the speedo settings are different due to different tyre size
shift times at a bit quicker and trans pressure's at bit higher in the 2011 tune
everything in the same
i will have a good look later tonight and see if i can find any more
The only differnce I have seen is from the early 2010's until the late 2010's. I have only tuned one 2011 and its tune was the same as a late 2010.
