Subd
Subd
The more I learn, the more I realize I have to learn still. I was under then impression with the latency you fellows were talking about, it would play into the timing via the pulse width. i will devote more thinking/learning time to the matter. Thanks THEFERMANATOR for your insight once again.
I believe the "timing calculators" are being mentioned due to the shorter pulsewidth that a larger injector will have for a given commanded fuel value. Thus, if your old "stock" injectors were at like 2000 us and now your larger ones only need say 1200 us to inject the same amount of fuel .... then you should be able to reduce your timing value to try and center up where your start of injection and stop of injection are occurring. So people have mentioned shooting for like 50/50 split (degrees BTDC ... degrees ATDC).
Latency is pretty constant from stock to oversize inejctors, and is used in figuring out your modified pulsewidth's for oversized injecotrs. It has no bearing on timing or the calculators as they use RPM, pulsewidth, and rail pressure to figure your timing to obtain a certain amount of injection before TDC.
I'm looking to do this for a friends truck who recently put in 30 overs. Where did you adjust the 37.5% in table? I was told to do like 22% at around 160mpa and starting at 1200us. And idle to only reduce around 5%. So did you reduce 37.5% on the whole table? or just the upper areas?
