Transferring stream license to other unit
Hello,
I can buy a new in box V2 fairly cheap locally to replace my V2 with a dead usb port, so i cant update that one. It has been send out to SoCal for repair but it would have to be replaced. Can i get my stream license and other vin transfered to the 'New to me' unit? I can still use my old unit to flash LS1B, since i use the SD card to transfer files.
The unit would need to be returned to New Zealand to remove the stream from one unit and put it on another. There is a fee for this service.
You will most likely want the stream moved onto a brand new V2 that can be custom made with the same license number as your original to maintain compatibility with your existing files for linking/unlinking and locking/unlocking purposes. A second hand new to you unit would not have this capability.
Contact sales@efilive.com for more information .
