2 Attachment(s)
Help! LS3 Swap Running Issues
Just finished an LS swap and having running/idling issues. I am new to EFILive and tuning in general. Hoping someone can take a look at the tune file and a short data log and offer some insight and possibly spot any issues that is keeping this thing from running.
The swap consists of an 07 L92 Escalade motor put in a 86 Porsche 944. The only mods made were an LS3 intake, Bosch 42lbs injectors, Ls3 DBW throttle body, Holley sniper fuel rails, stock Corvette pressure regulator and headers. Basically converted to an Ls3 keeping the VVT. All sensors are stock minus the MAF, O2's and MAP which are new stock LS3 parts. The car has a stock manual 5 speed with an aftermarket VSS sensor. I used a standalone harness, E38 ecm and Corvette DBW pedal from PSI. The ecm was supposedly flashed, VATS removed etc with a base tune for all the above parts. The car currently does not have an exhaust, running through open headers. I installed header extensions with bungs for the O2's.
The car fires right up, idles poorly for 10 seconds or so and then starts surging and sputtering. I can keep it running for a bit by playing with the gas pedal, but ultimately I loose the pedal completely and it dies. Running pig rich and fouling the plugs only after maybe a minute of run time.
The only DTC I am getting is a MAP sensor code. I checked the sensor and ref, signal, ground voltages seem to check out. KOEO kpa is around 100 and KEOR is around 50 which seems right from my reading.
A buddy managed to download the tune file and a short running data log with EFILive. Files attached.
Thanks in advance guys!
