Yes, correct, calc_pids.txt.
After *CLC-00-002 there is *CLC-00-00... looks like this be *CLC-00-003.
Actually it was a total mess, I was on my tuning laptop using Notepad. Never have 2 or more instances open in Notepad! I blew it. That file was all messed up as you noticed. It's still missing CLC-00-003... and look in *PRN - Parameter Reference Numbers at number 3? It's 303, shouldn't that be down lower in order?...
I use EditPad on my shop laptop. What do you use or recommend?
Notepad++ is my go-to free editor for basic things like this and minor programming. Might do what you want plus has a tabbed interface. :)
That works for free as well as my 2005 paid for version of EditPad which needed a paid for update! :thumb_yello:
Since *CLC-00-003 was missing in that, you replaced it with *CLC-00-303 which is what I need here I just moved it.
Is it acceptable to Comment out a entry? Look at:
*CLC-00-273
# *CLC-00-273
Attachment 14356
Yes you can comment out like that;
it is not complete tho, you will have to provide CLC and PRN entries for CALC.B4901.
Think I got procedure right. Not sure I have all correct changes done, going to test.
Understand that I have experiance with sytax from HTML. CGI etc... and learning how/what/why these entries work.
That calc_pids file may look good but it does not work, one entry twice. Going back to start again.
Guess what happens if you get all the right PIDS and calc_pid file correct?
It works!
At this point I'm not sure which tutorial I followed, but the corrections for fuel and MAF are being done Closed Loop with MAF sensor hooked up in one log!
:jump:
