Is there plans for EFI to work with non GM vehicles? Found this in scan tool manual.
Quote:
Vehicle/Powertrain
Features
GM LS1/LS2 and compatible controllers Duramax LB7/LLY controllers Allison transmission controllers
• Display and clear diagnostic trouble codes
• EPA test results
• Generic PIDs
• Enhanced PIDs
• DMA PIDs
• Bidirectional controls
• Learned fuel trim cells
• Miscellaneous calibration data
• Scan modes:
o General
o Dynamic
o Stream-Slow
o Stream-Fast
GM Custom SAE J1850 VPW
EFILive provides user level configuration files that may be edited, so that EFILive can log most OBD II compliant GM vehicle’s enhanced parameters.
If you know the vehicle’s enhanced parameters’ PID numbers and SLOT details, then you can create a configuration to support that GM vehicle.
Ford
Not supported yet.
DaimlerChrysler
Not supported yet.
support@efilive.com - 22 -
www.efilive.com
So does this mean there are plans for Ford and Chrysler products to be supported by EFI? That would be great, I could turn my wifes town & country into a hotrod as well as my brother's F-250.
