http://forum.efilive.com/attachment....2&d=1266532272
Thanks for that. Just because I like to be sure, this is what I'm after right?
Attachment 16522
Yes, that's correct.
I have an Innovate DB gauge, in the installation instructions, it says to tie the ground to the same ground source shared with the wideband controller.
Presumably this doesn't need to be on the same bung, so long as it's the same ground?
Also, I guess the 12V switched (for illumination) doesn't need to be the same 12V switched source as the controller (presumably better if it's separate?)
For reference the Innovate install instructions are here.
My apologies for the simple questions, here's another diagram just in case it helps someone in the future understand :)
Attachment 16524
