adding fuel pressure and WB02 into ecu.
Hi all,
I'm looking to add fuel pressure and WBO2 into my ecu so that I can easily log with efilive. Later I plan to monitor both with an OBD2 style gauge that polls off the data lines, which is why I'd rather not run either signal analog into the V2.
I have found the tutorial for adding fuel pressure to the ecu using the egr circuit. If this is done, can I add WB02 in through the a/c pressure circuit? Looking at the LC2 from innovate so I can program it to be linear 0-5v no problem.
Do you guys think this would work?
