I just checked the DropBox, there are 5 tunes for 2002 Commodores there. I'm betting there's something behind the scenes that's causing these issues, I'd start with a bone stock, 2002 Commodore file and go from there. It wont give you the 12212156 OS, but 12225074 is a well supported OS as well. You can run COS3 with that OS and it is the proper base OS for your vehicle.
I dont see the 12212156 OS being used on any Commodore per the DropBox, however that could be incorrect as I've never seen one in person.
There is COS5 for these two GM OS's:
- 12225074 Holden LS1 2002-4 -> upgrades to COS5 01290005
- 12212156 Camaro/Firebird 2002 -> upgrades to COS5 02020005
There you go, use the 12225074 as the base OS and you should be set.
