Cam sensor wiring pinout
Hi guys,
I have an 05 model ls2 with the 24x and 1x trigger wheels. Using a cam sensor in the timing case GM part no:12585545. Would anyone know what the pinout should be for this sensor? There is no ABC on it, but it has +,-,O. Guessing O is signal?? Can't seem to find a definite answer.
Post a pic of the connector on the end of the sensor, and indicate which pins are + - o
my guess: + = signal (A), - = low reference/return (B), o = 12V reference (C).
All good thanks. It was as we thought
Which symbol represents the signal...?
+ is 12v ref, - is ground, O is signal
