2 Attachment(s)
IAC steps very high.
Alright, so I have been doing a bunch of reading and most people are saying, even with a cammed engine I should have about 50-60 steps on the IAC at idle.
I am seeing about 120-150 steps. If I force anything less with DVT, the engine immediately dies. What could cause this? I know I have a larger cam, but I have seen guys with larger or equal cams to me and they aren't this high on IAC steps.
Cam is Comp 230/238 .600 .603 @ 114.
Any ideas from latest logs?
Attachment 17523
Attachment 17524
What intake and throttle body are you running?
Stock truck intake and stock 78mm TB.
You'll have to adjust the TB open some more in order to lower the IAC steps.
I am in a 2000 Silverado. It doesn't really have a TB adjustment. It is a DBW.
If it's DBW there is no IAC hence no IAC steps to count.
I don't think 2000 silverados came DBW????
Some pre-2003 Trucks were DBW. If it is a 2000 model, then it probably uses OS12205612.
Take a look at the idle airflow values - generally these need to be increased slightly with a larger (non-OEM) camshaft. Start with B4307 and B4308 - then look at the corrections parameters if you are still having issues.
2 Attachment(s)
Sorry guys, it is DBC. My bad. I have got the idle airflow values to where it idles perfectly driving and cruising, but I am still at 150+ on steps.
Here is latest log and tune.
Attachment 17549
Attachment 17548
If it drives and idles fine, leave it alone.
If not crack the throttle stop open until counts are down around 30-50, be careful not to go too far or TPS volts may go out of range, (you may have to do a TPS reset) .
Then log and adjust Running airflow again.
I agree if it runs and drives fine. Leave it alone. Don't get to caught up in the counts.
