The developer and I are catching up next week to discuss.
Cheers
Cindy
Cheers
Cindy
I hope those tables will be added to 18 trucks OS 12683365 also
Pressure ratio limit and desired coolant temp have been added. B5221 was already defined in this OS. The developer could not find B5220.
Attached is the updated calz file for 12683365 as listed in post #1. We expect that these enhancements will be added to other operating systems later this week. The timing on that will determine if they are included in the next release - I suspect given the current stage of testing that the release may occur before the rest of the OS's are updated.
Cheers
Cindy
The next EFILive software release will contain updates to 37 E92 operating systems for desired eng temp, Fan control, Max boost pressure and max pressure ratio tables.
Cheers
Cindy
THanks Cindy But I hope if B5220 will be added for OS 12677878 if he could not find it in OS 12683365
What is b5220?
