Why not RR with A WBO2 ? That would work!! Are you using V1 or V2
I use V1 and need to pack around my PC to flash a tune But since you know what is going to be in your tank do you think it best as mentioned to just have 2 tunes. 1 E70 and 1 E98? Thats allot of work it would seem to do the sensor deal and questionable results. If you Use V2 it would seem you could flash the PCM with what ever fuel you need to use. Another thing that no one has mentioned Is the Road runner with a WBO2. That certainly would seem to let you dial in whatever AFR for the you are using on the fly with only a few logs since you are using a E70+.
That would be a cool and reliable setup?
Good Luck,
98 tigershark
[QUOTE=coctostan;98136] I want to run the fuel sensor because I will run different mixtures of Ethanol to Gas. When it is super hot in the summer I will run E98 at times. In the cooler months it will be E70. Anyway, my PCM currently isn't doing much more than fuel, spark, idle etc. Does this help?
Maybe I didnt say it right!
What I meant was , if there was and AFR gauge and he had RR. An example is : AFR gauge says lets say 9 for E70 and he puts in E98 then the AFR would jump up to 12.5 approx. That would let you know and then w/RR all you would have to do is change that for the fuel on the fly sort of.
I do know it is not a flex fuel adjustment in the PCM but it does at least let you know what you have in the tank. As in Stoich of 14.63 AFR gauge says 15.00, you know you have E10. True not a flex fuel setup but the gauge does let you know what is in your tank and W/RR cant you change B3601 on the fly?
BTW thanks for the Vette show link. That was nice of you!! Have a good Sunday!
98 tigershark
Quote:
Originally Posted by
mr.prick
Remember the point of this thread? ;)
B3601 needs to be changed for type of fuel.
Like I said if your tune is good all you should have to change is the EQ1 value.
I read that we do not get E10 but since then I have talked to a truck driver that
was filling up the tanks at a local gas station.
He told me we get it in the winter even tho we aren't mandated to use it.
I am morally against Ethanol but it would be nice to get the extra power from it
and we do not have any choice in the winter. :bad:
Adding the FF tables via COS would probably be the only way to integrate them to an OS that does not have them although it might be possible with a .cax
I have not heard back from Ross yet. :gossip:
FYI we just had a big Vette show downtown. (I didn't go) :bad:
Corvettes jam downtown in classic display
