Known issues with the April 2016 Beta Test Release
Currently known issues and possible workarounds for the March 2016 Beta Test Release of the EFILive Software and Firmware
Download the April 2016 beta test release here: https://forum.efilive.com/showthread...a-Test-Release
Download the public stable-release here: http://www.efilive.com/latest/cat/download-efilive
Beta test release software versions:
- Software: V7.5.7.304
- Software: V8.2.2.295
- FlashScan/AutoCal firmware: V2.07.98
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
Workaround:
EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
V7 tunetool: doe snot show difference summary for VVE/coefficients
When you do Display Calibration Difference Summary, it does not show any differences in Normal VE Coefficients and/or Virtual VE table...
( if you look at those tables and click the CAL, ALT, +/-, %, |%| buttons you will see the differences ok )
V7 tunetool: red ETC folder
Currently require V2or V1 to be connected in order make the red ETC folder visible...
instead of requiring V2/V1 to be connected, can the visibility of the red ETC folder be made an option (i.e. in the Options)
(and with a warning if it is necessary; and of course, the warning would have an option to silence it)...?
