Added CPP to LS1b, what tables are affected?
2005 LS1b, LQ9, 228R cam, headers. M6 trans.
I started with a mail order tune which got me running(good not great). The tune was setup to run without a CPP. I want to make sure I update all the correct tables now to reap the benifits. If you guys know of anything else I should be concentrating on, I'm all ears(and eyes, well, mostly just eyes).
I'm aware of TC and TF in Gear and P/N.
Rolling Idle is currently zero'd out...will this ask for "zero" rpm if I depress clutch and TC is active? Maybe just enter 800rpm across the board?
Base Spark in Gear{B5932}
Base Spark P/N{B5933} these are the same...should I change them?
Lastly, and keep in mind I'm new, after I complete RAFPN, do I need to redo now for RAFIG?
Thanks for any responses guys.
