411 ecu with 98 Vette pedal tac and ls2 tbody issues
As title says,having some issues,custom 2 bar os runs and drives perfect,fueling isn't spot on yet but close enough to drive.anything more then 10psi and it goes into limp mode.base file I started with was a 2156 02 Vette auto that a did a trans segiment swap for a 4l60 from Camaro so it doesn't think it's a trans axle.runs and drives great.ive raised every airflow table I can find some more then needed I'm sure.can someone smarter then me chime in with some tips or info.thanks alot.
