All:
I have a 2017 3500 Cummins and am having a difficult time locating a stock file.
I am getting a GT to disable the encryption, but I haven't seen much information on how/where to obtain a base file.
Thoughts?
All:
Thoughts?
Good Question! I may need to do this to a 16 model So I am also trying to find this info as well.
Goto starlite diesel they can help you
CMD:
Link Deleted
CME Cab & Chassis:
Link Deleted
CME Pickup:
Link Deleted
Files were faulty, they have been deleted off Mega.
I have downloaded them to my Dropbox. I am getting a few unusual errors.... When I try to open a 2013-2015 file, I get an unrecognized PCM error.
V7.5 will open a 2016-2018 file with no issue. However, when I try to save any changes to these files. I get an error 400000 code. I now can't make any changes to the calibration I previously built, MY17 68FRE.... I also downloaded the latest v7.5 and v8. When I received the same error codes, I unistalled and reinstalled both V7.5 and v8. Any thoughts..?
You will get that on some of those OS's, it was just a mass collection of ones the factory has released over many years. All the latest factory updates in there should be supported, see the pdf below for a cross reference.
http://kb.dcctools.com/index.php?Vie...6&AttachID=167
I cannot duplicate this issue, but I am running some pre-release software that has being built after the public release.
You are running these versions right?
https://forum.efilive.com/showthread...ase-(Nov-2017)
I've pulled the files down and deleted the links. They were accidentally created with software that will not be compatible with any public releases. I will revisit this next week to fix it.
