Just wanted to confirm if the cell highlighted in the tune file is always the cell being referenced by the car's computer.
I am using the custom calibration number 3.
When I do this only the first column is being highlighted.
Thanks,
Bill
Thanks,
Bill
The LS1_Link file for the controller must not be mapped for that particular OS. Edit the file in C:\Program Files (x86)\EFILive\V7.5\Configuration and make sure the table you're looking at has the correct values mapped in the file.
Thanks ScarabEpic22. I will try to look into that as well.
Post pic.
Check units are same between logged pid and table columns.
Thanks Joecar. I will verify.
joecar you were exactly right. Even though my map showed the same units the pid default was set to SAE. When I made that change it was consistent with the map log. Thanks
Good deal, thanks for confirming.
