July 2016, Release Candidate 3
Please download and install both the V7.5 and V8 software packages.
Both the V7.5 and V8 software were updated in Release Candidate 3, you should download and install both V7.5 and V8 software packages.
Release Notes:
Version Numbers:
After installation, you should have the following software, boot block and firmware versions installed:
EFILive V7 software: V7.5.7 Build 309 To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 302 To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.102 (July 08, 2015) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
Known Issues
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
Issue 2:
When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
Workaround:
EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
Issue 3:
The "What's New" release notes displayed in the EFILive V8 software show the firmware date as July 04, 2016.
Workaround:
The firmware date should be July 08, 2016.
