you might have to explain it mate...
I know he's not having a dig at you, trust me :)
remember, we are different (or everyone else is different), we down under view things differently, my wife (born in Anaheim) always reminds me :)
Attachment 21227
Compared to a stock file there appear to be many changes (unless I have the wrong stock file to compare against)...
did this file start life as a F-car file or as truck file (looks like truck file)...?
Everyone knows you've got a busy life, but you still come in here and try to help people. Sometimes it takes a few days before you can look over someone's tune file... "There's a lot to look at in this tune file" is Aussie humor for "you might be waiting a while before Joe gets back to you".
Started as a van I do believe, then converted to COS5, then got a 4L80 added in, and most recently added the 2 bar setup. The only thing preventing me from reverting my IFR and doing a calc.vet is this assumption that I'll adversely affect transient fueling. Since I'm not aware of any transient parameters that I can change, I ASSume the only way is to fudge it in the IFR. Kinda like an older 5.0 Ford I was playing with. Didn't have tuning software, but did have an adjustable FPR and that was the only thing that fixed the off idle stumble in that car (which had better flowing heads and intake and exhaust than stock).
I know he's a busy guy so I don't want him needlessly looking too much at a tune that I think I know what is wrong with. On the other hand, the only thing I have to lose is gas, but I gain experience. I should probably point out that driveability is good enough for me to DD the thing. When warm I see the wideband peg full lean momentarily but it doesn't seem to stumble and fall on its face so badly then, only when cold. I'm kinda curious if there isn't just a bad handoff from the idle stuff to the VE. Either way that requires VE to be correct. How can I know if my calculated IFR just isn't jiving with the tune?
There's something wrong with your setup. At 3000rpm WOT, you're only getting 96kPa manifold pressure... even at a high elevation, you'd expect more than that with a boosted engine.
What MAP sensor are you using? What elevation are you at?
lol, that's what I thought :)
I look at everything, I learn alot from it (and I don't mind), and I'm not going to let lack of time deter me :)
statesman is right, I have so many things going all at once (family health, job, 2nd job, upgrading my Trans Am, EFILive, keeping up at LS1tech, sleep) but I can't give up any of them.
+1 what statesman said about VE and MAF tables... and the place where you see it show up the most/worst is at idle.
I'm at 6000' so a typical day is 77-79kpa. I believe that puts me in the ~3.5# boost range on something that claims about 5# at sea level on a stock engine. Mine has a freer flowing intake manifold and exhaust setup than stock. Cam is very close to stock, just has a smidge more duration and lift but better airflow nonetheless. I'm not sure how significant of an impact the elevation should have on a mildly boosted engine. Here's the MAP that I used, ACDelco 213-1631 from a Supercharged Cobalt I do believe.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I should also mention the only injector data that I changed was IFR, everything else I left as it was.
